Admittance [Bode plot]
Admittance [Bode plot] - Admittance [Bode plot] - 消息
#1 已发布: 2018/5/20 19:46:13
983个赞,共6,866个帖子。
The ZedGraph log did crash my Smath session.
Otherwise Bode data set is 1/1 MCD.
Project Admittance Copy.sm (47.46 KiB)已下载 1436 次。
#2 已发布: 2018/5/21 09:59:57
Arie
Arie
94个赞,共285个帖子。
Fixed for ZedGraph in attached. Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings.
Project Admittance Copy_alyles.sm (90.53 KiB)已下载 1400 次。
#3 已发布: 2018/5/21 11:45:19
983个赞,共6,866个帖子。
Fixed for ZedGraph in attached.Zedgraph inputs only accept two columns. One must adjust points/line settings within the formatting window settings.
Thanks alyles, just doctored before your attachment.
I noticed ZedGraph does not support spline, unlike ordinary XY.
Project Admittance.sm (87.83 KiB)已下载 1344 次。
#4 已发布: 2018/5/21 21:36:17
983个赞,共6,866个帖子。
... [suite]
this Smath document has been doctored/finished for publishing.
Bode gain plot, phase plot ... both log plot X direction.
Project Admittance Copy.sm (150.21 KiB)已下载 1345 次。
#5 已发布: 2018/5/22 10:58:42
983个赞,共6,866个帖子。
... more general definition of phase:
Project Admittance Copy.sm (155.54 KiB)已下载 1363 次。
#6 已发布: 2018/5/22 13:32:28
Arie
Arie
94个赞,共285个帖子。
Figured out how to use Maxima's Draw2D(). This also looks nice for a logx plot. Plotted both Admittance and Phase in same graph. I like this as well because properties can be changed directly in SMath sheet.
I played around with XY Plot but was unable to find a way to use log axes.
Project Admittance Copy_Maxima_Draw2D_alyles.sm (183.41 KiB)已下载 1476 次。
3位用户喜欢此帖子
frapuano 2018/5/22 18:26:00, Martin Kraska 2018/5/22 13:46:00, Davide Carpi 2018/5/23 06:10:00
#7 已发布: 2018/5/22 13:55:59
1,362个赞,共2,276个帖子。
Nice example!
I did a bit of cleanup, removed the markers and shifted some options to the settings dialog.
2018-05-22 18_50_32-SMath Studio - [Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm_].png
Project%20Admittance%20Copy_Maxima_Draw2D_alyles_Kr.sm (97.31 KiB)已下载 1608 次。
4位用户喜欢此帖子
Davide Carpi 2018/5/23 06:09:00, frapuano 2018/5/22 18:26:00, Arie 2018/5/22 14:22:00, sergio 2018/5/22 15:00:00
