1页(8条)
Custom Function Plugin Error in SS 6520 - 消息
I am experiencing problem in installing CustomFunctions Plugin in SS 6520 (07/11/2017).
Even some items {(such as cases(), abs()}in the Function Index of Reference book have problems.
I am using Win 10 64 bit latest update.
Pl test the attached example.
Small Dams Flood Routing Ex-Program Method-Original-Simple3.sm (863.28 KiB)已下载 1542 次。
3位用户喜欢此帖子
Confirmed as well,
NDTM Amarasekera 2017/11/9 23:47:00
Thank you, I'll fix it ASAP. As usual please be patient and keep reporting issues
WroteEven some items {(such as cases(), abs()}in the Function Index of Reference book have problems.
They might be related to the new rendering system. I miss the issues with abs() (not related to CustomFunctions, though), could you post a screenshoot? Thanks in advance.
Thanks David. Following Screenshots(SC) are taken before updating Custom Functions Plugin.
SC 1: Selected Function Index of Reference Book.
SC 2: abs() selected and before updating Custom Functions.
I will let you know the situation after updating Custom Functions.
未找到文件。 未找到文件。
ndtma
未找到文件。 未找到文件。
ndtma
"The mind is everything. What you think you become."
Descartes said it otherwise: "je pense, donc je suis"
First intelligent expression since mankind !
This was said by Lord Buddha about 2600 years ago. I only quoted it.
Thanks.
Thanks.
Ah yes, there is a Conjugate() function in that worksheet
1页(8条)
