1页(13条)
chart with 3 axis Y - 消息
Is it possible to make such a chart with three Y axes on a single chart?
something like this
https://ibb.co/JcRn2B9
something like this
In case you want to have more than one Y value axis, in"XY Plugin" you can set two different Y axis scales: some traces will refer to Y1, some to Y2
I think that there is not "out of the box" tool to have three or more Y axis.
WroteIs it possible to make such a chart with three Y axes on a single chart?
You can have as many as you want of fake style like the image.
Create Y's as image and slide close to the plot.
You can do lot more Professional ... associate each graph with Nodes Labels.
Cheers ... Jean.
Using X-Y Plot Region, you can simulate your graph with any number of axes, but needs some programming like in this example.
XYPlot. Linear polar.sm (61.18 KiB)已下载 1264 次。
Hi. Also, you can do that in Plotly:
https://plotly.com/chart-studio-help/excel/three-y-axes/
and then put it into SMath, but I don't know how to use the plugin, or if it is available:
https://en.smath.com/forum/yaf_postst17372_Plotly.aspx
WroteYou can have as many as you want of fake style like the image.
... as many as you want horizontal/vertical,
disposed inner wrt the Quick Plot
otherwise outside X_Y past build-in default 2.
Utilities XY Label Graph MORE.sm (35.86 KiB)已下载 1304 次。
... from this factory demo.
Utilities XY Label Graph Y.sm (22.32 KiB)已下载 1229 次。
... for whatever end use, add margins/calipers.
Utilities XY Label Graph Y factory.sm (41.03 KiB)已下载 1287 次。
thanks for helping everyone. I used plotly and coped with the charts.
Hello
I think your graph could be like this
Three_exes_Graf.sm (32.97 KiB)已下载 1272 次。
1页(13条)
