1页(4条)
how to display minutes in a result? - Is there a smart way for display of minutes in a result? - 消息
Dear community,
Again I have another beginner question:
I wonder if there is a smarter way than mine to display "minutes" in a result. I did not manage to use the search function since search terms like "time" or "minute" or "angle" deliver too many results.
My problem is to show results of time and angular calculations in a user friendly way. Currently I do it by putting the values into a matrix (see example). But this is mathematically incorrect.
Does anybody have a smart solution for this ... e.g. a user defined unit?
Thanks in advance for every idea!
Best regards,
Ralf
未找到文件。未找到文件。
Best regards,
Ralf
未找到文件。未找到文件。
I don't know if my solution is smarter, but the display is closer to what you want. The seconds symbol should be " but that doesn't work.
DMS.sm (9.78 KiB)已下载 1200 次。
sergio 2018/4/2 05:15:00
WroteThanks in advance for every idea!
Maybe you can set as you wish, getting inspired from Martin guidance.
Maths Convert [deg, min, sec].sm (4.76 KiB)已下载 1061 次。
1页(4条)
