Function as variable for another function
Function as variable for another function - Is it possible to use function as variable for function if in this functon is if statement.. - 消息
#1 已发布: 2020/9/27 17:24:11
Rihards
Rihards
0个赞,共2个帖子。
function doesnt work if in argument function there is if
is it possible to add function as argument to another function if in that function is if statement?
#2 已发布: 2020/9/27 17:41:02
1,139个赞,共1,805个帖子。
I guess that you have an unit issue, instead to ask "x=1" try with "x=1*'m".
#3 已发布: 2020/9/27 17:51:46
Rihards
Rihards
0个赞,共2个帖子。
引用
no i tried with out any units.. as far as i can tell its if there is if in the function i cant use it as argument for another function even if it plots perfect as i imagine..111fff.PNG
so i played around even further:
it seems that: i can make boolean operations with x and i can use if if x is not evaluated.. but if in if statement there is x then it shows that x is not defined.? is this bug?
#4 已发布: 2020/9/27 19:46:38
1,139个赞,共1,805个帖子。
This is an "if-issue". It can't be integrate, nor derivate (sometimes) and also can't be called in this way. As workaround use cases.
#5 已发布: 2020/9/27 20:45:03
983个赞,共6,866个帖子。
If you have no plot => you have no project.
#6 已发布: 2020/9/27 21:07:15
983个赞,共6,866个帖子。
Smath Bible is largely in Samples
Integrate Discontinuous_1.sm (24.52 KiB)已下载 1208 次。
#7 已发布: 2020/9/27 21:17:25
983个赞,共6,866个帖子。
Integral 0Discrete Cumulative 10 styles.sm (179.98 KiB)已下载 1172 次。
