Vectorize Issue: How to Get 2D Matrix Output?
Vectorize Issue: How to Get 2D Matrix Output? - 消息
#41 已发布: 2022/4/22 16:12:10
983个赞,共6,866个帖子。
Download Kirby NIST data set ... fit.
I will correct your defective design.
Just that one for learning step.
#42 已发布: 2022/4/22 16:25:13
600个赞,共1,381个帖子。
Yeah, you should learn there is no such thing as kW/hr.
Unit of power is kW, it is written as kilowatt. No time involved.
And poise is the unit of dynamic viscosity. (Pa*s) or (kg/m*s)
In pump calculation you should use stokes. (m^2/s)
#43 已发布: 2022/4/22 16:51:42
Mark R Harris
Mark R Harris
5个赞,共90个帖子。
It would have been a really fast learning step if SMath's units were used from the outset.
Time for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks.
This has not been pleasant to watch.
#44 已发布: 2022/4/23 19:53:59
983个赞,共6,866个帖子。
Yes Mark, adapt project system/standards,
accordingly to the Control Engineer Tool Box ... standards
Nothing dogmatic/Bible.
Cheers ... Jean.
Mark R Harris 2022/4/23 20:01:00
#45 已发布: 2022/4/23 20:05:34
Mark R Harris
Mark R Harris
5个赞,共90个帖子。
Cheers ... Jean.
Excellent, thanks Jean.
It may be worth doing some weeding to remove examples that may lead noobies astray.
