Problem with integral (again)
Problem with integral (again) - Definite Integral - 消息
#1 已发布: 2022/12/15 12:03:46
Peter Pal Ther
Peter Pal Ther
0个赞,共3个帖子。
Hi!
I have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem?
Thanks a lot!
Bye
Pali
HF.sm (72.86 KiB)已下载 1313 次。
#2 已发布: 2022/12/15 14:31:15
983个赞,共6,866个帖子。
Can you explain me, what is the problem ?
In some way doctored in red. Setup the integrator scalar wrt 'x'.
Cheers ... Jean.
HF.sm (84.02 KiB)已下载 1333 次。
#3 已发布: 2022/12/15 15:01:55
1,139个赞,共1,805个帖子。
Hi Pali. At this time, you can't use if(..) inside an integral, use cases(...) instead. Also, SMath's integral new version can handle better units.
HF.sm (73.15 KiB)已下载 1325 次。
#4 已发布: 2022/12/16 06:41:10
Peter Pal Ther
Peter Pal Ther
0个赞,共3个帖子。
Hi Alvaro,
thanks a lot! It works fine. Thank you.
What do you mean: new version of integral?
Pali
#5 已发布: 2022/12/16 06:42:49
Peter Pal Ther
Peter Pal Ther
0个赞,共3个帖子。
Cheers ... Jean.
I do not really understand what you did, but thanks for your help as well.
#6 已发布: 2022/12/16 09:37:18
983个赞,共6,866个帖子。
1. recast if/else ► if/otherwise.
2. made ∫ scalar wrt 'x' for local/vectorize
HFshort.sm (23.97 KiB)已下载 1282 次。
#7 已发布: 2022/12/16 14:49:11
1,139个赞,共1,805个帖子。
Hi Pali. In the "new" version of the integral it puts the units of the result correctly, while before some corrections had to be made. From "list of changes" here: Defined Integral supports units now.
Davide Carpi 2022/12/16 18:26:00
