how do i can solve a trigonometric equation which is restricted arguments?
how do i can solve a trigonometric equation which is restricted arguments? - maple software - 消息
#1 已发布: 2021/7/4 23:50:31
hamideh
hamideh
0个赞,共3个帖子。
Hi
i want to solve an equation about adding three cosine term which are constrained:
cos(2 pi(x+y-2z))+cos(2 pi(y+z-2x))+cos(2 pi(z+x-2y))=0
with constraint 0
can some one please guide me?
i wrote this command but it did not work:
solve({cos(2*Pi*(x+y-2*z))+cos(2*Pi*(y+z-2*x))+cos(2*Pi*(z+x-2*y)) = 0, 0 <= x, x <= 1, y <= 1, z <= 1, x < y, y < z}, [x, y, z], explicit)
when we write this command as this:
solve({cos(2*Pi*(x+y-2*z))+cos(2*Pi*(y+z-2*x))+cos(2*Pi*(z+x-2*y)) = 0,[x, y, z], explicit)
i do not see any change in the figures
apparently my restriction do not work!
whats the problem?
someone told me i should solve this problem with Draghilev method because this problem should solve with numerical method
#2 已发布: 2021/7/5 10:41:14
600个赞,共1,381个帖子。
More experienced users may help you better than me.
But your equation seems to have infinite solutions.
al_nleqsolve equ(x,y,z).sm (10.75 KiB)已下载 1226 次。
#3 已发布: 2021/7/5 18:20:46
1,139个赞,共1,805个帖子。
As overlord points, there are infinite solutions. Just like the better visual representation for z = f(x,y) is a surface in the 3D space, w = f(x,y,z) is a hypersurface in the 4D space. But we can't see that plot. So, here a plot of families of that 4D hypersurface, like a contour plot, but with surfaces.
About Dragilev method, I can't find my setup for 3D, and the expert there is Viacheslav (uni).
Plots4D.sm (111.28 KiB)已下载 1294 次。
Plots4D.pdf (393.96 KiB)已下载 875 次。
Oscar Campo 2021/7/5 21:01:00
#4 已发布: 2021/7/5 21:15:59
983个赞,共6,866个帖子。
#5 已发布: 2021/7/6 01:46:40
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
One of the solutions by the Draghilev method.
Draghilev.sm (23.95 KiB)已下载 1214 次。
Alvaro 2021/7/6 03:06:00
#6 已发布: 2021/7/6 03:05:22
1,139个赞,共1,805个帖子。
Well, Fridel it's an expert too, thanks.
Joining above Dragilev and 4D methods.
Plots4D_DM3.sm (111.83 KiB)已下载 1257 次。
Plots4D_DM3.pdf (182.28 KiB)已下载 787 次。
Fridel Selitsky 2021/7/6 03:50:00
#7 已发布: 2021/7/6 12:19:07
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Discussion of this problem on the maple forum featuring
the author of this question(rahmati)
https://www.mapleprimes.com/questions/232488-How-Do-I-Can-Solve-A-Trigonometric-Equation
