[SS-2267] ImportData and dec separator
[SS-2267] ImportData and dec separator - 消息
#1 已发布: 2015/3/26 17:53:37
1,362个赞,共2,276个帖子。
I want to read a text file using ImportData() and can't understand the effect of the dec separator setting (second argument)
The first version with correct specification does not work.
The other versions with default or wrong specification do work. But they don't work on some other computers.
This is the contents of the file:
显示剧透
This is the system information
显示剧透
As this might largely system dependent, I would like to get this tested by others before committing a bug report in the bts
importdatabug.sm (7.93 KiB)已下载 1428 次。
#2 已发布: 2015/3/27 10:49:41
1,443个赞,共2,936个帖子。
Same result as your if I use comma as decimal separator and semicolon as argument separator
the result below is if I use period as decimal separator and comma as argument separator
显示剧透
