Conditionally Formatted Labels - Add Conditionally Formatted Labels in SMath Studio worksheets - Messages
#81 Posted: 1/17/2023 9:19:38 AM
Here it is.
losa-forum.sm (862.11 KiB) downloaded 1930 time(s).
Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
#82 Posted: 1/17/2023 10:18:15 AM
#83 Posted: 1/17/2023 10:55:42 AM
WroteHere it is.
Document does not open ... incorrect format
#84 Posted: 1/17/2023 11:15:28 AM
#85 Posted: 1/17/2023 11:20:05 AM
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error.
![2023-01-17 15_10_16-SMath Solver - [losa-forum.sm_].png](/en-US/files/Download/EWoMa6/2023-01-17-15_10_16-SMath-Solver---[losa-forum.sm_].png)
The same happens if you try to force a numerical evaluation using eval()
![2023-01-17 15_23_37-SMath Solver - [losa-forum.sm_].png](/en-US/files/Download/uxxyYx/2023-01-17-15_23_37-SMath-Solver---[losa-forum.sm_].png)
#86 Posted: 1/17/2023 12:05:21 PM
#87 Posted: 1/17/2023 12:12:05 PM
WroteSMath Studio Desktop 64-bit
Version: 1.0(build: 8348)
Date: 9/11/2022
Slide left the Formatted Label
Side right the graph, remove the Σ no definido
You should see the plot.
#88 Posted: 1/17/2023 12:15:52 PM
WroteThat is it!
As allways thanks!!
You're welcome!
WroteBut still don't understand why Jean files fails.
If you remove the 3 inline evaluations it will work.
![2023-01-17 16_28_05-SMath Solver - [Image Formated LABEL [Oxyhemoglobin] FORUM.sm].png](/en-US/files/Download/8DEVaV/2023-01-17-16_28_05-SMath-Solver---[Image-Formated-LABEL-[Oxyhemoglobin]-FORUM.sm].png)
#89 Posted: 1/17/2023 12:39:57 PM
There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter.nevermind I was looking at your file.
My file can be an example of things NOT to do.
#90 Posted: 10/14/2023 11:08:58 PM
Can we manage the units that are displayed?
I have a load in kN/m2 and the result appears as kg/(m*s2).
The idea is to present only positive values (with the appropriate unit).
kind regards
Conditionally Formatted Labels_unity.sm (5.47 KiB) downloaded 1888 time(s).
kind regards
#92 Posted: 10/15/2023 12:08:06 AM
Thank you very much.
This is exactly what I needed.
#93 Posted: 10/15/2023 11:51:23 PM
I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
#94 Posted: 10/16/2023 3:06:16 AM
WroteI'm looking for a way to represent the letter D as a subscript
You can subscribe whatever.
mysystem dot HelloGrandMa
#95 Posted: 10/17/2023 1:32:30 AM
WroteWroteI'm looking for a way to represent the letter D as a subscript
thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing.
Davide sent the function shown above in which I need to use subscripts.
#96 Posted: 10/17/2023 2:13:46 AM
Davide used superscript unicode character for write: "kN\002F\m\00B2\" wich renders as "kN/m²" so, you can use unicode characters...but not all characters have subscript version.
Please check here: https://www.compart.com/en/unicode/search?q=subscript#characters
Oscar
Oscar
#97 Posted: 10/17/2023 1:30:37 PM
Hi Karol. This could be a workaround, using the SMath Plot region.
label.sm (6.22 KiB) downloaded 1864 time(s).
Oscar Campo 10/17/2023 4:52:00 PM
#98 Posted: 10/17/2023 6:15:56 PM
Subscripts in native Solver 30405.
Collect as many the project needs,
call the wanted by indexing.
Maths Subscript.sm (10.73 KiB) downloaded 1886 time(s).
#99 Posted: 10/17/2023 11:23:29 PM
#100 Posted: 10/17/2023 11:26:39 PM
WroteSubscripts in native Solver 30405.
Jean Giraud,
Thank you too.
But I have to put in some effort to understand what you sent.
Kind regards
![2023-10-14 18_53_23-SMath Solver - [Conditionally Formatted Labels_unity.sm_].png](/en-US/files/Download/2aoqAw/2023-10-14-18_53_23-SMath-Solver---[Conditionally-Formatted-Labels_unity.sm_].png)
