Maxima Plugin
Maxima Plugin - Сообщения
#81 Опубликовано: 11.03.2014 16:55:51
You are right, that is a bug in the translation (already in the Todo in SVN). Kay is on vacation...
Radovan Omorjan 11.03.2014 17:12:00
#82 Опубликовано: 30.03.2014 07:40:19
  • Due to registring a path to Maxima during setup, SMath is not really portable any more unless you can use the same Maxima path on different systems
    [/list]
  • Thank you very much, Kay and Martin!!
    You may want to contact the author of the portable version of Maxima at portableapps.com
    http://portableapps.com/node/23391
    There is now a workaround to use SMath and Maxima on a portable storage device http://smath.info/bts/Issues/IssueDetail.aspx?id=94
    Remaining problems:
    • Path to Maxima must be edited by hand in maxima.xml
    • X-Maxima must be launched at least once on a given host system in order to create temp directories on the host system (portable Maxima is just configured like that)
    Radovan Omorjan 30.03.2014 08:01:00, ioan92 30.03.2014 08:16:00
    #83 Опубликовано: 30.03.2014 09:08:36
    Hello Martin,
    Thank you for this one
    I did not managed to make temporary file by starting X-Maxima, and I just made it myself and it works this way.
    ioan92 30.03.2014 09:28:00
    #84 Опубликовано: 30.03.2014 10:02:07
    Radovan, can you please show the output of SettingsDirectory()? Perhaps you do not use portable SMath.
    #85 Опубликовано: 30.03.2014 10:44:56
    Here it is. USB Stick is on F: . I started X-Maxima.exe few times (seen on the screenshot) and wxMaxima opened. I just closed it then. As I could see no plot when opening the test file, on the debug window was a message of unexisting X-Maxima temp folder. Just created it manually, and then it worked.
    Hmm..., should I run F:\SMath\Maxima\Bin\Maxima\bin\xmaxima.exe ? I run it, it does not help it.
    Look at this video please
    Anyway, I have to make X-Maxima folder manually.
    Martin Kraska 30.03.2014 12:51:00
    #86 Опубликовано: 30.03.2014 12:31:34
    Radovan, thanks for the feedback.
    Perhaps I found a way to tell Maxima not to use the host system. You might give it a try
    Comment out the four lines immediately above the win9x label in maxima.bat
    rem if "C:\Users\Kraska" == "" goto win9x
    rem if "%MAXIMA_USERDIR%" == "" set MAXIMA_USERDIR=G:\SMath\Maxima\User\Maxima
    rem if "%MAXIMA_TEMPDIR%" == "" set MAXIMA_TEMPDIR=D:\tmp\X-Maxima
    rem goto startparseargs
    :win9x
    #87 Опубликовано: 30.03.2014 14:01:50
    :win9x
    Ha - it works . I've noted that X-Maxima temp folder was not needed anymore (I deleted it). I tried your sample file and could see that the temporary graphics files resides in th USB stick inside Maxima plugin temporary gnuplot.output foder. It disappears when SMath was closed.
    I also tried your Drw2D3D example. Unfortunately, there are some problems here. I've noted that the graphics files appear inside SMath install folder (not in the file folder - here F:\Temp) but they do not appear in the Worksheet. See the video please. I might missed something here of course.
    I also changed the path for Maxima - it is relative path inside maxima.xml now (you deleted the post about it, but I saw it before that )
    Maxima\Bin\Maxima\bin\maxima.bat
    One more thing. I just used maxima.xml from my regular install because I could not find it on the stick.
    EDIT: I updated the plugins from the the Gallery for USB Stick SMath+X-Maxima. The sample file is Ok, but there might be some mess because Draw2D3D file can not be opened with SMath from the stick - here is the error
    EDIT2: I tried some more files with Maxima and draw and USB Stick SMath+X-Maxima. Some of them are Ok and some of them are not. I suppose some time will be needed to stabilize the things.
    #88 Опубликовано: 30.03.2014 18:53:48
    Radovan, thanks for your patience with the plugin.
    The file appears when Maxima is first called in the given installation. Updates of the plugin take care of your local settings, therefore, this is normally not an issue.
    You can install Maxima side by side to SMath and use a relative path like ..\Maxima. Thus no need to interfere with the SMath directory.
    I can open and execute the Draw2D3D examples except some of them (using 0.97.5189 both ordinary and portable).
    Could you please inspect and show the log messages for failing plots and operations? Just issue MaximaLog() next to the plot.
    #89 Опубликовано: 31.03.2014 07:15:59
    Hello Martin,
    It seems I figured out something. I used the USB version and wanted to get a plot with the previously saved graph file. It appeared that the formed graph files were saved in the SMath folder but there were no pictures in the SMath Worksheet. When I restarted Maxima, then plots appeared and the plot files in the same folder where the file SMath file resides. Now, after recalculation SVG is reloaded but PNG is not - that was strange. I am not sure this behavior is expected. Anyway, see this video file please. I hope you could see it because I used large portion of the screen.
    The same error with your Draw2D3D examples file and the USB version. I could not opened it here on my office computer (Win7 x64) and therefore could not produce Log file. I have the impression that for the moment this portable version on the stick is working quite good.
    #90 Опубликовано: 31.03.2014 09:12:51
    Some remarks:
    - load(draw) is not required, when using Draw2D() and Draw3D()
    - when no image file names are given, then the names are randomized and the files reside in a temporary directory in the plugin dir, regardless what the current directory is.
    - when image file names are given, then they are relative to the current directory. This may or may not be the directory of the current document. Check or set this using CurrentDirectory().
    - You can set the current directory to the document directory using CurrentDirectory(DocumentDirectory())=, that is what I recommend to do when using explicit file names.
    - In order to identify the SMath-version and current directory in videos, I recommend to show the output of SettingsDirectory() (which tells portable from standard) and CurrentDirectory()
    - I observed problems with the image files. They are not written by Maxima if they are in use by the image region. I don't know, if that is an image region problem or a Maxima problem and when exactly this emerged. If you slightly change the name, then the image is updated. For randomized names, this problem does not occure, because the name changes upon each re-calculation.
    @uni: Do you have any idea, what recent change could stop another program to write files that are opened in the image region? If not, we have to search for reasons inside Maxima or inside the plugin.
    Edit: The image region is perhaps not to blame. The problem is limited to png files (svg files can be written locally and also be updated when they are open in the image region).
    I filed this as issue SS-97 in the bug tracker.
    #91 Опубликовано: 31.03.2014 13:02:00
    Thank you Martin for the reply,
    I figured out what happened and I will take care on your remarks. It seems that the *.png bug is a bit problematic. I think that crashes on my office machine happened due to this problem - not sure.
    Moreover, I figured out that I had to put:
    MaximaControl(restart)=
    in order Draw2d() to write files inside document directory, otherwise they will be written in SMath folder.
    The command
    did not help at all.
    #92 Опубликовано: 04.04.2014 15:53:48
    Under http://billinghurst.customer.netspace.net.au/maxima-5.33.0.exe you find a preliminary
    installer for Maxima-5.33.0
    This version seems to work with SMath including the Draw features.
    #93 Опубликовано: 04.04.2014 17:17:45
    Confirmed,
    It seems that png still does not reload
    #94 Опубликовано: 06.04.2014 15:54:58
    Plugin updated.
    Changes:
    - diff(1) fixed
    - extended logging functions, including export to wxm (wxMaxima file)
    - New function MaximaDefine() to set variables in Maxima.
    - SS-84 implemented. Draw2D/3D now can handle units (expressions with units do not
    freeze maxima any more)
    - SS-90 implemented. Warnings of float to rational conversions are suppressed.
    - SS-87 implemented. Maxima sets can be specified (mainly for use in draw options)
    - SS-57 fixed. Names with multiple separators are translated correctly
    Plugin Maxima Test.sm (469,79 КиБ) скачан 1697 раз(а).
    Radovan Omorjan 06.04.2014 17:03:00
    #95 Опубликовано: 06.04.2014 17:05:21
    Just opening the PluginMaximaTest.sm file. The plot2d was not presented.
    Everything else seems to be correct.
    #96 Опубликовано: 06.04.2014 17:53:23
    it works for me (Maxima 5.30.0)
    Best regards,
    Davide
    #97 Опубликовано: 07.04.2014 15:33:27
    That seems to be a path or current dir issue. Has the png file been generated at the location indicated by the plot command? Then, using this path for the image region should do the job.
    #98 Опубликовано: 07.04.2014 16:30:46
    You are right. I just used the full path and there is png files saved there. Should it be this way?
    #99 Опубликовано: 07.04.2014 18:35:05
    Definitely not, because this is not portable. Send the sheet to someone else and it will fail. Somehow the current directories in SMath (where the image region acts) and Maxima (where the image is generated) do not match.
    Kay and me, we discussed the issue of how to match the paths in a reliable way and we decided to leave everyting that depends on current directory settings in the responsibility of the user. Thus, if you set a relative file name for the image, you must make sure yourself that you find the image.
    Normally I find using CurrentDirectory(DocumentDirectory()) or just opening the sheet by doubleclick in the file manager (thereby starting an SMath session with current dir where the file is and a clean new maxima session) being sufficient to avoid path problems.
    If you do not need the image as a separate product but just want to display it, then we offer the temporary storage in the plugin dir, using dynamically created absolute paths. If you still badly need matching current directories in SMath and Maxima, then you might file a feature request. However, this might not be easy going to implement.
    #100 Опубликовано: 08.04.2014 01:11:20
    By the way, Draw2D will work with temporary picture and a named one correctly. If you use "grün.png" in Draw2D then it will be saved in the current directory. As we mentioned before, this picture could not be deleted from the current directory until we close the SMath file. Moreover, if we named it as "grün.png" it will be saved as png file named "grün.png.png" and if we named it like "grün" it will be save as svg file named "grün.svg".
