One more about lens
One more about lens - 消息
#1 已发布: 2024/12/1 01:52:00
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
How can we use here a Mathcad-block?
Lens-Mathcad-Block.sm (43.8 KiB)已下载 1856 次。
See too
https://en.smath.com/forum/yaf_postst25212_Lens.aspx
#2 已发布: 2024/12/1 18:08:12
1,558个赞,共1,868个帖子。
Here the function rkfixed() can't process the incoming expressions correctly. The block has nothing to do with it, it does not perform detailed analysis of expressions.
This is a bug in the function. The function has not been tested for this case. I can't see what's wrong here right now.
Valery Ochkov 2024/12/2 15:44:00
#3 已发布: 2024/12/1 19:52:45
1,362个赞,共2,276个帖子。
This is not a solution of the rkfixed problem, just a little playing around with X-Y plot.
Here, an option of setting the aspect ratio of the axes to 1 would be good.
未找到文件。未找到文件。
2位用户喜欢此帖子
Valery Ochkov 2024/12/2 15:45:00, francesco rapuano 2024/12/3 04:21:00
#4 已发布: 2024/12/7 13:02:58
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Mathcad Prime
#5 已发布: 2024/12/8 01:05:34
Cornel
Cornel
2个赞,共78个帖子。
I am wondering if there is such a kind of Mathcad Prime odesolve for solving differential equations numerically also for SMath Studio somehow?
#6 已发布: 2024/12/8 01:21:21
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Not yet, but will be soon!
Question - why is the answer meters squared, and not just meters?
#7 已发布: 2024/12/8 02:29:44
1,558个赞,共1,868个帖子。
What's wrong with the existing solvers?
#8 已发布: 2024/12/8 03:54:39
Cornel
Cornel
2个赞,共78个帖子。
Because odesolve in Mathcad Prime:
1. Do not require to rewrite the differential equation of a higher order into a system of first order odes
2. Determines whether a system is stiff or nonstiff and then is using accordingly the stiff numerical differential eq solver or nonstiff numerical differential eq solver
3. Can solve numerically a system of differential equations (whatever it's a system of first order differential eq or a system of higher order differential eq)
What are these existing numerical solvers of differential eq in SMath? What are the posibilities of SMath to solve numerically differential equations? Exist at least one solver that mimic the Mathcad Prime odesolve (i.e. the 3 points above menționed)?
#9 已发布: 2024/12/8 05:04:39
1,139个赞,共1,805个帖子。
Hi Cornel. For points 1 and 3, SMath can do what Mathcad can, and just a little more. Please, check the first post in this plugin. Can mathcad solve this odes?
RKA.sm (308.62 KiB)已下载 2283 次。
RKA.pdf (931.16 KiB)已下载 1760 次。
About point 2, one would have to review the documentation for the following plugins to see if they are capable, and to what extent, of doing what you are asking, and choose it for the solver in the SMath's solver block.
● [topic=17088]Intel ODE Solver Library[/topic]
● [topic=1918]DotNumerics[/topic]
● [topic=13809]SADEL[/topic]
● [topic=1970]Matlab C++ Math Library[/topic]
● [topic=17063]OSLO[/topic]
● [topic=17067]lsoda[/topic]
● [topic=1997]GNU Scientific Library (GSL)[/topic]
#10 已发布: 2024/12/8 08:58:47
1,139个赞,共1,805个帖子。
See too
Hi. dsol can solve it with this setup:
RKA-Lens.sm (179.91 KiB)已下载 1825 次。
I also use the Martin's setup for the plot.
#11 已发布: 2024/12/9 10:44:48
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
How to create this picture
https://en.wikipedia.org/wiki/Spherical_aberration
#12 已发布: 2024/12/10 04:11:05
1,139个赞,共1,805个帖子。
Hi Valery. This is a way.
spherical aberration.sm (15.88 KiB)已下载 1815 次。
2位用户喜欢此帖子
Oscar Campo 2024/12/10 09:43:00, Valery Ochkov 2024/12/10 12:26:00
#13 已发布: 2024/12/10 12:38:25
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Thanks!
The last step
#14 已发布: 2024/12/10 21:21:41
1,139个赞,共1,805个帖子。
Hi. The screen. I also simplify a little the calculations.
spherical aberration.sm (26.41 KiB)已下载 1974 次。
3位用户喜欢此帖子
francesco rapuano 2024/12/10 23:05:00, NDTM Amarasekera 2024/12/10 23:16:00, Вячеслав Мезенцев 2024/12/10 23:19:00
#15 已发布: 2024/12/10 21:35:39
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
Very elegant solution
Alvaro 2024/12/11 06:18:00
#16 已发布: 2024/12/11 03:06:13
1,362个赞,共2,276个帖子。
Root-free version of the spherical lens
spherical aberration_Kr.sm (12.37 KiB)已下载 1754 次。
#17 已发布: 2024/12/11 06:22:06
1,139个赞,共1,805个帖子。
Gracias Oscar! Pero espérate tantito nomás para que veas lo que puede hacer un doc alemán.
Thanks Oscar! But wait a little longer so you can see what a German doctor can do.
Oscar Campo 2024/12/11 12:09:00
#18 已发布: 2024/12/12 04:49:07
1,558个赞,共1,868个帖子。
2位用户喜欢此帖子
Oscar Campo 2024/12/12 18:29:00, Alvaro 2024/12/13 07:27:00
