Modeller Region - Introduction of Modeller Region with how to use step-by-step instruction - 消息
At the moment I cannot drag any object from the template pane to the modeller region.
I am using 0.99 (6839)
But you can test it easily by opening the example in the first post online. There it doesn't work, too.
Also the tooltip by hovering the any template objects appears only rarely.
Editing already exiting objects works fine.
kind regards,
Martin
I have downloaded an examples with modeller region and I can move/change shapes in modeller but I can't add new shapes from templates bar.
Does anybody can help ?
WroteI can't add new shapes from templates bar.
You can only add shapes that you have created or borrowed from unknown sources
In this document, two objects were created and installed in the template
N =5 => yellow square
N 13 => light gray dodecagon
Check if it works in your SS version
modeller-demo-Kr.sm (15.04 KiB)已下载 1547 次。
I have opened your document and I see that 3 shapes (2 dodecagon and 1 square) have you added to moddeller work space from template bar.
But I can't select and add any shape from template.
As I said - drag and drop function not works.
One more thing.
I have downloaded "RainboGame.exe" and drag and drop function works fine.
But it has not work in "exe" files created by me.
WroteAt the moment I cannot drag any object from the template pane to the modeller region.
WroteThe "Drag and drop" function is not working
Updated, please try now.
Now I can drag and drop shapes but I can't zoom in and out shapes using mouse scroll.
WroteNow I can drag and drop shapes but I can't zoom in and out shapes using mouse scroll.
You can only zoom the modeller canvas, not the single shapes (even in previous versions).
P.S. another update made because templates weren't detected on mouse move (no template name shown, f.e.)
WroteYou can only zoom the modeller canvas, not the single shapes (even in previous versions).
SS 6179, zoom is by handles and thus fabricate otherwise than native.
1. The blue line come automatically 45° ... make it as thick as desired.
2. The arrow, you can rotate at will from the creation.
Observe the the empty "" fill arrow
3. Fill color applies to closed shapes
4. for some weird figure it can be done by digitizing and collecting the XY vector.
Modeler takes only pairwise XY vector ... not matrix
modeller-demo-Kr.sm (27.66 KiB)已下载 1531 次。
Some cleanup needed ...
modeller-demo-Kr.sm (133.16 KiB)已下载 1580 次。
See attached.
Modeller - Shapes - Canvas Center.sm (11.29 KiB)已下载 1561 次。
WroteIs there anyway to have the center of the modeler canvas moved so that (0,0) is not at the center?
Maybe YES ... in the attached objects are disposed/located.
modeller-demo-Kr.sm (162.97 KiB)已下载 1520 次。
AFAIK, not as you state it. Why do that ?
1. Slide the shape [circle] in the canvas.
2. Click-in to see the dotted frame [3 big black dots per side]
3. Double click to get the coordinated [X,Y]...[0,0 = centered canvas]
...width/height for circle/ellipse ...size the shape [zoom ±].
If you have some difficulties ... please don't hesitate.
Yes, but to make it interactive, you need slider regions. Use a function as predefined layout. It's third and fourth arguments are channels to convey the canvas co-ordinates.
The canvas is centered at these co-ordinates, evaluated for the default scale.
The default scale is given by the second entry of the dependent layout row vector.
Modeller%20-%20Shapes%20-%20Canvas%20Center_Kr.sm (13.6 KiB)已下载 1832 次。
![2020-01-03 14_33_43-SMath Studio 0.99.7251 - [Modeller%20-%20Shapes%20-%20Canvas%20Center.sm_].png](/zh-Hans-CN/files/Download/y8Czpz/2020-01-03-14_33_43-SMath-Studio-0.99.7251---[Modeller%20-%20Shapes%20-%20Canvas%20Center.sm_].png)
WroteJean, in your example you could specify an appropriate default size of the objects. Then the arrow template doesn't appear as a single dot any more.
Thanks Martin, most appreciated ... updated.
modeller-demo-Kr.sm (162.81 KiB)已下载 1599 次。
![2020-01-03 13_59_21-SMath Studio 0.99.7251 - [modeller-demo-Kr.sm_].png](/zh-Hans-CN/files/Download/WbgXyc/2020-01-03-13_59_21-SMath-Studio-0.99.7251---[modeller-demo-Kr.sm_].png)
