Modeller Region
Modeller Region - Introduction of Modeller Region with how to use step-by-step instruction - 消息
#61 已发布: 2020/1/4 11:06:45
Ryan Freund
Ryan Freund
20个赞,共339个帖子。
Thanks Martin and Jean. The slider is pretty neat.
#62 已发布: 2021/3/21 15:19:02
Renzo Choque
Renzo Choque
6个赞,共18个帖子。
Hello, thanks for this magnificent plugin it is very useful but all its functions are not documented.
It would be great if someone could upload the documentation of all the features of the plugin because discovering them one by one is a bit cumbersome.
Thank you very much in advance
#63 已发布: 2021/8/6 23:56:25
Renzo Choque
Renzo Choque
6个赞,共18个帖子。
Hello, please someone knows how to rotate text in modeller region?
#64 已发布: 2021/8/7 18:26:59
1,139个赞,共1,805个帖子。
Hi. This is a workaround, based on https://en.smath.com/forum/yaf_postst20332_Drawing-Text.aspx
DrawingTextModeller.pdf (104.58 KiB)已下载 1000 次。
DrawingTextModeller.sm (278.08 KiB)已下载 1790 次。
#65 已发布: 2021/8/8 14:26:40
Renzo Choque
Renzo Choque
6个赞,共18个帖子。
Thanks Alvaro, your implementation is very interesting, but I would like to know how to rotate the normal text (green label) without distorting it.
#66 已发布: 2021/8/10 07:59:32
1,443个赞,共2,936个帖子。
Use 270 as 4th argument to rotate 90° counter-clockwise
2位用户喜欢此帖子
Jason McCool 2021/8/10 11:38:00, Oscar Campo 2021/8/10 11:54:00
#67 已发布: 2021/8/10 12:54:54
600个赞,共1,381个帖子。
Text Rotation in modeller region with 270 as fourth argument is not working under Linux.
I had encountered this several months ago, maybe years. Forgot to report it.
#68 已发布: 2021/8/11 05:34:50
1,443个赞,共2,936个帖子。
Text Rotatior in modeller region with 270 as fourth argument is not working under Linux.
I'll look into it, thank you.
#69 已发布: 2021/8/11 10:56:20
983个赞,共6,866个帖子。
Thanks Davide for rotated text in Modeler.
modeller Rotate Text.sm (177.71 KiB)已下载 1809 次。
#70 已发布: 2021/8/12 14:53:06
600个赞,共1,381个帖子。
This is how it is rendered with rotated text.
