Data Exchange plugin
Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - 消息
#181 已发布: 2021/5/23 07:44:04
1,443个赞,共2,936个帖子。
PLUGIN UPDATED SMath Studio 0.99.7808 and later
  • fixed encoding/decoding issues;
  • refactoring;
#182 已发布: 2021/8/5 10:04:01
Stefano
Stefano
0个赞,共22个帖子。
when saving as odt with the option to convert to libreoffice math object, negative quantities loose the minus sign only if the haven't any other element in front of them. For example:
引用
a:=4-9=-5
it get converted to
引用
a:=4-9=5
For context, I just discovered this app so it could be that I am simply ignoring something obvious.
未找到文件。->未找到文件。
#183 已发布: 2021/8/5 17:25:52
1,443个赞,共2,936个帖子。
Seems a bug in the plugin, thank you for reporting it
#184 已发布: 2021/12/24 01:52:45
susilo widyatmoko
susilo widyatmoko
5个赞,共9个帖子。
can I use this plugin (csv export) in viewer/exe file? so user can get output from exe file
#185 已发布: 2021/12/29 20:16:47
1,443个赞,共2,936个帖子。
Hello [userlink]Susilo Widyatmoko[/userlink],
Yes, you can. If you want to let the user choose a path, there is the path picker region, otherwise you might choose a default output, f.e. if you choose an empty string as third argument ("") the file will be created next to the executable.
#186 已发布: 2022/6/3 08:56:14
RaiHil
RaiHil
0个赞,共2个帖子。
Hello Davide,
thank You for Your very useful Plug-in!
I use it regularly to paste my Smath calculations into MS Word.
In order to be able to arrange and organize formulas and text better, I use text regions.
Unfortunately, text regions containing formulas are not saved properly in the *.odt files.
Would it be possible to modify the the Plug-in in order to alloy the correct reprensentation of text regions containing formulas in the *.odt files?
Thank You verry much
Raimund
#187 已发布: 2022/6/6 13:51:47
1,443个赞,共2,936个帖子。
Hello [userlink]RaiHil[/userlink]
I'll look into it, although last time I've checked nested regions weren't easy to manage plugin-side.
#188 已发布: 2022/6/9 11:52:55
RaiHil
RaiHil
0个赞,共2个帖子。
Thank you, I appreciate your effort!
