Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - 消息
PLUGIN UPDATED SMath Studio 0.99.7808 and later
- fixed encoding/decoding issues;
- refactoring;
when saving as odt with the option to convert to libreoffice math object, negative quantities loose the minus sign only if the haven't any other element in front of them. For example:
For context, I just discovered this app so it could be that I am simply ignoring something obvious.
未找到文件。->未找到文件。
it get converted to引用a:=4-9=-5
引用a:=4-9=5
未找到文件。->未找到文件。
Seems a bug in the plugin, thank you for reporting it
can I use this plugin (csv export) in viewer/exe file? so user can get output from exe file
Hello [userlink]Susilo Widyatmoko[/userlink],
Yes, you can. If you want to let the user choose a path, there is the path picker region, otherwise you might choose a default output, f.e. if you choose an empty string as third argument ("") the file will be created next to the executable.
Wrotecan I use this plugin (csv export) in viewer/exe file? so user can get output from exe file
Hello Davide,
thank You for Your very useful Plug-in!
I use it regularly to paste my Smath calculations into MS Word.
In order to be able to arrange and organize formulas and text better, I use text regions.
Unfortunately, text regions containing formulas are not saved properly in the *.odt files.
Would it be possible to modify the the Plug-in in order to alloy the correct reprensentation of text regions containing formulas in the *.odt files?
Thank You verry much
Raimund
Raimund
Hello [userlink]RaiHil[/userlink]
I'll look into it, although last time I've checked nested regions weren't easy to manage plugin-side.
WroteUnfortunately, text regions containing formulas are not saved properly in the *.odt files.
WroteHello [userlink]RaiHil[/userlink]
Thank you, I appreciate your effort!
