FIR Filter Design
FIR Filter Design - Calculation of digital filter coefficients - 消息
#1 已发布: 2013/5/6 15:05:06
1,558个赞,共1,868个帖子。
FIR Filter Design
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
Functions list: remez(4), remez2(4).
remez(vg, vr, vw, n) Returns coefficients for a FIR filter of length n generated by the Remez exchange algorithm.
Arguments:
- vg is a real vector, a grid of frequencies between 0 and 0.5.
- vr is a real vector of values between 0 and 1, length: vg / 2. Contains the frequency response over vg.
- vw is a real vector of values between 0 and 1, the same length as vr. Contains error weight over vg.
- n is an integer, the length of the filter.
Links:
1. Based on Parks-McClellan algorithm for FIR filter design (C version) by Jake Janovetz (part of the Analysis of Functional NeuroImages - a set of C programs for processing, analyzing, and displaying functional MRI (FMRI) data).
2. Parks-McClellan filter design algorithm.
remez.sm (13.43 KiB)已下载 1922 次。
remez.pdf (48.9 KiB)已下载 1232 次。
See also:
1. Design FIR band-pass/stop filters up to length ~2000
FIRFilterDesign. Example 1 (rus).pdf (100.06 KiB)已下载 1139 次。
2位用户喜欢此帖子
Davide Carpi 2013/5/6 17:21:00, Andrey Ivashov 2013/5/6 17:41:00
#2 已发布: 2021/11/17 17:20:00
1,558个赞,共1,868个帖子。
Plugin updated. Please try.
Changes:
- remez2() function added.
Links:
1. Sources from tomtit
2. Test example for remez2().
#3 已发布: 2021/12/29 14:34:56
1,558个赞,共1,868个帖子。
Calculation of digital filter coefficients for emulation/design High-Class Audio Multi-function Digital Filter SM5842AP/APT.
High-Class Audio Multi-function Digital Filter (SM5842AP-APT).sm (26.64 KiB)已下载 1740 次。
High-Class Audio Multi-function Digital Filter (SM5842AP-APT).pdf (169.04 KiB)已下载 1011 次。
SM5842AP.pdf (218.37 KiB)已下载 1253 次。
Click to enlarge Click to enlarge
Links:
1. The example is audiophile's "holy" NPC SM5842 8X interpolating digital filter.
Davide Carpi 2021/12/29 20:17:00
