CoolProp Wrapper
CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - 消息
#61 已发布: 2023/4/21 15:17:35
1,558个赞,共1,868个帖子。
How can I get properties of mixtures e.g
CoolProp_Props("Dmass","T",273+100,"P",101.3*10^3,"Helium[0.5]&Xenon[0.5]"
ref: http://www.coolprop.org/fluid_properties/Mixtures.html
This can't be done directly in the current version of the plugin. It is not clear how to call the apply_simple_mixing_rule() function from the library, it can't be imported as it is not in the export table.
Click to enlarge
Click to enlarge
maple-python-coolprop.sm (6.61 KiB)已下载 1977 次。
maple-python-coolprop.pdf (19.18 KiB)已下载 1395 次。
Click to enlarge
maple-python-coolprop-2.sm (5.08 KiB)已下载 1934 次。
#62 已发布: 2023/4/22 05:00:09
1,139个赞,共1,805个帖子。
Hi. Notice that Refprop from NIST can't handle He/Xe mixing either. At least version 9.
On the other hand, maple doesn't seem to implement the procedure that Viacheslav points out either, as can be seen in the online documentation for the latest version.
However, very good values can be obtained using Coolprop in SMath and some basic stoichiometry.
Mixing gases.sm (19.17 KiB)已下载 1930 次。
Mixing gases.pdf (67.22 KiB)已下载 1328 次。
#63 已发布: 2023/4/22 05:34:44
1,558个赞,共1,868个帖子。
More simple
Click to enlarge Click to enlarge Click to enlarge
maple-python-coolprop-3.sm (10.97 KiB)已下载 1935 次。
maple-python-coolprop-3.1.sm (10.82 KiB)已下载 1940 次。
maple-python-coolprop-3.2.sm (10.89 KiB)已下载 1848 次。
Alvaro 2023/4/22 09:32:00
#64 已发布: 2023/4/27 03:09:34
1,558个赞,共1,868个帖子。
Now you can write like this
maple-python-coolprop-3.3.sm (9.51 KiB)已下载 1946 次。
#65 已发布: 2023/4/28 07:39:13
1,558个赞,共1,868个帖子。
Or like this
maple-python-coolprop-3.4.sm (10.66 KiB)已下载 1951 次。
maple-python-coolprop-3.5.sm (10.3 KiB)已下载 1911 次。
#66 已发布: 2023/4/29 15:33:10
1,558个赞,共1,868个帖子。
Click to enlarge
maple-python-coolprop-3.6.sm (9.98 KiB)已下载 1892 次。
#67 已发布: 2023/4/29 22:07:03
churichuro
churichuro
29个赞,共79个帖子。
is fantastic!
this no work the first time but after I play with the another examples this work, very well
thank you!
#68 已发布: 2023/5/4 10:29:17
1,558个赞,共1,868个帖子。
Without "pyfile" (inline multiline script). The script should be without comments.
Space padding is necessary here so that inside the script, when a large string is divided into parts, the line break character itself is not divided ( '\n' -> '\ n' ).
maple-python-coolprop-3.7.sm (9.9 KiB)已下载 1935 次。
maple-python-coolprop-3.8.sm (6.84 KiB)已下载 1932 次。
maple-python-coolprop-3.9.sm (8 KiB)已下载 1903 次。
#69 已发布: 2023/7/30 08:12:32
usamakhan
usamakhan
7个赞,共98个帖子。
Uni, can you please help me how to add python into SMATH, I have python already in system [WinPython 3.9] How I link it up with Smath?
I have working CoolProp
#70 已发布: 2023/7/30 13:33:42
usamakhan
usamakhan
7个赞,共98个帖子。
Jean, can you help me how do integrate python in my Smath? I event tried environmental variables under Win10 but didn't work
#71 已发布: 2023/7/31 03:45:32
1,558个赞,共1,868个帖子。
You should use a double slash for the full path.
In this case, you need to check whether python is available from the command line. If not, it means that the paths are specified incorrectly.
#72 已发布: 2023/8/2 19:17:11
usamakhan
usamakhan
7个赞,共98个帖子。
uni, thanks a lot
Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts]
Additionally Razonar sample here is also very intuitive while calculating mixing values
https://en.smath.com/forum/yaf_postsm82120_Understanding-Redlich-Kwong-equation-of-state.aspx#post82120
#73 已发布: 2023/8/3 03:06:16
1,558个赞,共1,868个帖子。
uni, thanks a lot
Mathcad Block from the Mathcad Toolbox plugin and just Text inside it for the script.
#74 已发布: 2023/8/4 15:23:07
usamakhan
usamakhan
7个赞,共98个帖子。
uni, so it means the text inside the block is not automatically generated. Can you please explain the construct
On second note you were correct, I fixed my environment variable under windows %python% now works
#75 已发布: 2023/8/8 02:01:18
1,139个赞,共1,805个帖子。
Phase diagrams with CoolProps.
Click to enlarge
PhaseDiagram.sm (39.17 KiB)已下载 1942 次。
Davide Carpi 2023/8/8 02:10:00
#76 已发布: 2023/8/9 03:47:50
1,139个赞,共1,805个帖子。
Psychrometric Chart with CoolProps. 'Simplified' version (more readable): Enthalpy lines overlap web bulb temperature lines.
Click to enlarge
PsychrometricChart.sm (125.39 KiB)已下载 1899 次。
#77 已发布: 2023/8/21 17:39:50
usamakhan
usamakhan
7个赞,共98个帖子。
I think I have found some problems while using plugin to get phase properties as discussed here: http://www.coolprop.org/coolprop/HighLevelAPI.html#imposing-the-phase-optional
First when using "P|phase_gas" it doesn't accept units & T,P values have to be directly written in SI equivalent
Second there is a value discrepancy when using "P" & "P|phase_gas" for a fluid that exists only in gas phase at that T,P
未找到文件。未找到文件。
#78 已发布: 2024/4/16 03:55:20
1,362个赞,共2,276个帖子。
It seems that multiple instances of SMath can't use the plugin at the same time.
How to reproduce:
1. Open SMath and access any Coolprop function
2. Open another SMath instance: You get an error message
#79 已发布: 2025/12/19 01:10:36
1,139个赞,共1,805个帖子。
Phase diagrams with CoolProps. ...
Now can show other thermo properties, and get animations.
PhaseDiagram.sm (46.88 KiB)已下载 898 次。
Animating volume of water and enthalpy of O2.
2位用户喜欢此帖子
Вячеслав Мезенцев 2025/12/19 18:44:49, Valery Ochkov 2026/6/23 08:27:38
#80 已发布: 2026/8/12 21:45:52
Nate Brown
Nate Brown
0个赞,共1个帖子。
I have a small feature request that I may be in the wrong spot to make. Anyway, I love how the CoolProp Wrapper is able to keep track of units and it's way more convenient than Excel or Python. Today I noticed that the wrapper is currently unable to handle units for derivatives. For example, the syntax of CoolProp_Props("d(C)/d(T)|P", "T", 300 K, "P", 1 atm, "Water") results in -0.3248 unitless. By doing a central difference around the same temperature with constant pressure, SMath+CoolProp will respond with -0.3248 J/kg·K². Is there a way that we can get the units into the shorter syntax?
