Rom2Arab
Rom2Arab - Arab2Rom - 消息
#1 已发布: 2023/10/18 22:06:10
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Why doesn't the cycle end?
See please the attachRome-Arab.sm (40.3 KiB)已下载 1539 次。
#2 已发布: 2023/10/19 00:53:00
Oscar Campo
Oscar Campo
135个赞,共309个帖子。
Really it's a very strange bahavior (a bug ?), because the value of variable n is cleared when function returns from Arab2Rom()
So, a solution is to use functions fwrite() and rfile() to save the value of n on a file as a memory:
See the atachment with the solution: Rome-Arab SOLVED.sm (41.21 KiB)已下载 1549 次。
best,
Oscar
Valery Ochkov 2023/10/19 01:08:00
#3 已发布: 2023/10/19 01:30:20
1,139个赞,共1,805个帖子。
Hi. In Arab2Rom(n) you modify n.
That's not good practice. This is a workaround for such cases.
2位用户喜欢此帖子
Valery Ochkov 2023/10/19 01:46:00, Oscar Campo 2023/10/19 01:46:00
#4 已发布: 2023/10/19 01:42:23
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Thanks!
But this have an error too!
Rom2Arab.sm (293.29 KiB)已下载 1529 次。
#5 已发布: 2023/10/19 01:52:56
1,139个赞,共1,805个帖子。
Thanks!
That's another function, not similar with the others above. Here the problem is the origin in Mathcad for strings. Try to set ORIGIN = 1 in Mathcad and rewrite the code.
#6 已发布: 2023/10/19 02:13:24
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
Thanks!
#7 已发布: 2023/10/19 02:43:57
1,139个赞,共1,805个帖子。
This is one way.
Valery Ochkov 2023/10/19 02:49:00
#8 已发布: 2023/10/19 02:49:12
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
This is one way.
Thanks,
send please the sm-file!
#9 已发布: 2023/10/23 00:30:24
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
My salary in 1980
ATM-SU.sm (6.29 KiB)已下载 1535 次。
#10 已发布: 2023/10/23 01:34:42
1,362个赞,共2,276个帖子。
If I remember correctly, 1988 a bottle of vodka (0.5l) was 3 rubles (if you got it at all, it was the time of prohibition - сухой закон). Therefore the 3-ruble-notes.
Valery Ochkov 2023/10/23 02:31:00
#11 已发布: 2023/10/23 02:24:31
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
2 рубля 87 копеек = 2.75 vodka + 0.12 bottle.
Three constants of soviet students 3.14, 2.87, 2.72
#12 已发布: 2023/10/28 16:11:54
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
There are also zeros in Roman numerals. See my photo from Greenwich.
And four is written this way IIII and not that way IV because there are only 12 and not 13 digits.
