differential equations
differential equations - solve differential equations - Messages
#21 Posted: 2019/12/26 18:32:57
Ale16595
Ale16595
0 likes in 35 posts.
Hi, sorry but I have practically no experience with this program and I find it difficult to understand the functions.
If you can please explain the various steps to be able to solve the differential equation in the picture.
I am interested in deriving the function phi (t), what do you need to know to solve the differential equation?
Thanks for your patience
Documento2 DE [explain more] (25).sm (48.29 KiB) downloaded 891 time(s).
#22 Posted: 2019/12/26 22:53:48
T
The setup to numerical DE solver is same as Mathcad,
even superior as it takes the parameters as vector.
Use p[1,2,3] for those parameters.
Up to what you proposed before: you don't have a DE
Those parameters are non-sense as they send the system in the zillion domain. Get that DE from the teacher, a bit of abstract would help.
Documento2 DE [explain more] (25).sm (71.7 KiB) downloaded 888 time(s).
#23 Posted: 2019/12/27 01:03:26
1,106 likes in 1,784 posts.
Hi. Usually we want know the ode and it's initial conditions. In your case you have boundary conditions, which can be solved by the shooting method.
Hope this helps.
motocicleta.sm (48.71 KiB) downloaded 1069 time(s).
motocicleta.pdf (203.43 KiB) downloaded 625 time(s).
frapuano 2019/12/27 05:52:00, sergio 2019/12/27 07:39:00
#24 Posted: 2019/12/27 07:45:06
Ale16595
Ale16595
My initial conditions are:
-phi(t = 0) = 0.146
-phi'(t = 0) = 0
#25 Posted: 2019/12/27 08:06:25
-phi(t = 0) = 0.146
-phi'(t = 0) = 0
For a Cauchy problem it's more easy.
motocicleta with IC.sm (37.14 KiB) downloaded 1043 time(s).
motocicleta with IC.pdf (136.74 KiB) downloaded 667 time(s).
3 users liked this post
Ale16595 2019/12/27 08:25:00, frapuano 2019/12/27 08:46:00, Вячеслав Мезенцев 2019/12/27 13:43:00
#26 Posted: 2019/12/27 08:26:00
Ale16595
Ale16595
Thank you very much,
regards
#27 Posted: 2019/12/27 13:12:31
This is an offer ... accept/reject ... go back to "square zero"
1. What maths are given/invented: a formula ?
2. From that formula, what is next
So, you have a formula and an objective project,
i.e: a pretty short work sheet not yet circular in the blue.
Ale16595 2019/12/27 14:06:00
#28 Posted: 2019/12/27 14:05:46
Ale16595
Ale16595
I appreciate the advice. I'm trying to learn
#29 Posted: 2019/12/27 15:51:08
Just give the formula that you were given.
or make an image from source ... learning is after.
#30 Posted: 2019/12/27 22:26:30
Read more about ODE ... just an initiating visit.
These two examples are Cauchy integration. They have no formal symbolic.
A discrete integration is possible via the module rkf4(y0,x0,x1,n,f).
From there: easy to get the discrete derivative.
ODE Cauchy Project.sm (27.38 KiB) downloaded 1088 time(s).
#31 Posted: 2019/12/28 18:49:56
Ale16595
Ale16595
Hi, sorry if I bother you again. I'm trying to integrate a function, the function in question is psi''(t) in order to derive psi'(t).
I tried using Simpson and Romberg's recursive methods, but without getting a solution.
Where am I wrong?
PROJECT.sm (69.12 KiB) downloaded 1109 time(s).
#32 Posted: 2019/12/28 21:59:18
You have phi in your document ... psi is a built-in function.
So, if phi''(t) is the 2nd derivative ... then the derivative
is simply the integral. To expedite fast: done discrete.
If you have questions: please re-post this document.
Cheers ... Jean.
PROJECT [1].sm (30.82 KiB) downloaded 887 time(s).
#33 Posted: 2019/12/28 23:19:45
.... in fact you have PSI''(t).
Maple does not find an explicit integral.
PROJECT [1].sm (21.91 KiB) downloaded 909 time(s).
#34 Posted: 2019/12/29 09:18:44
... lot more maths in there.
PROJECT [1].sm (44.37 KiB) downloaded 910 time(s).
#35 Posted: 2019/12/29 11:16:00
Where am I wrong?
Hi. You can use any Runge Kutta solver for integration.
Also, you can use SMath int procedure, but it's very (very) slow:
For the theory, remember that you can integrate (with definite integrals) both sides of an equation and get an equality too, which don't work with derivatives.
PROJECT.sm (74.9 KiB) downloaded 1097 time(s).
frapuano 2019/12/29 14:27:00
#36 Posted: 2019/12/29 11:21:10
Ale16595
Ale16595
Hi, I have calculated the function psi '(t) through dn_GearsBDF.
But now I can't calculate the ratio in the picture.
The error says, "The matrix must be square"
PROJECT.sm (57.24 KiB) downloaded 1099 time(s).
#37 Posted: 2019/12/29 14:19:55
Result from numerical ODE solvers is a data set.
Generate an interpolation scalar to 'x' ... then plot.
@ the end of the document ... more questions: -this one.
PROJECT (1).sm (74.9 KiB) downloaded 1078 time(s).
