1页(15条)
f(x, y) - 3D plot and optimal point - Steam Turbine - 消息
I have f(x, y) - thermal efficiency of a steam turbine with two steam extractions for heating feed water depending on the extraction pressures.
Question.
1. How to find the optimal pressure values at which the efficiency will be maximum?
2. Is it possible to build a surface? For now I have two separate 2D graphics.
More https://link.springer.com/book/10.1007/978-3-319-26674-9
2RegP-Ideal-new.sm (94.95 KiB)已下载 1590 次。
Question.
I am not familiar with CoolProps but I think I could make a nice 3D plot with Maxima if you provide the smath file
Valery Ochkov 2023/11/7 13:09:00
OK but I need a file where the wsp calls are replaced by coolprop ones. Even if plotting doesn't work as expected.
WroteOK but I need a file where the wsp calls are replaced by coolprop ones. Even if plotting doesn't work as expected.
See please attach
2RegP-Ideal-Cool_Prop-95.sm (73.63 KiB)已下载 1570 次。
2RegP-Ideal-Cool_Prop-95.pdf (361.44 KiB)已下载 958 次。
Martin (and all), I am waiting for the solution - 3D-plot and optimal values of p1 and p2.
2位用户喜欢此帖子
WroteNo, you cannot replace WaterSteamPro with Cool Prop for water/steam.
WaterSteamPro is a certified program!
Agreed: CoolProp is CoolProp.
For quick visit, I use freeware Katmar IAPWS=97 in all sorts of units.
By same token, in Smath, we have lot of water/steam formulas.
What about you tabulate matrix style, then spline/interpolate.
I will be back on your document ... Jean
Valery Ochkov 2023/11/9 18:37:00
WroteWroteNo, you cannot replace WaterSteamPro with Cool Prop for water/steam.
... confirmed vs my formula IAPWS-97
I get slightly different values. Still no automatic optimization because the objective function doesn't translate to Maxima. As a first step I made the function more robust by solving the two equations sequentially instead of simultaneously. In the original version sampling for the plot occasionally failed.
Plot MPa.pdf (219.47 KiB)已下载 957 次。
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (157.12 KiB)已下载 1588 次。
![2023-11-11 19_21_55-SMath Solver - [2RegP-Ideal-Cool_Prop-95_Kr_detail.sm_].png](/zh-Hans-CN/files/Download/GSNxMg/2023-11-11-19_21_55-SMath-Solver---[2RegP-Ideal-Cool_Prop-95_Kr_detail.sm_].png)
2RegP-Ideal-Cool_Prop-95_Kr_detail.pdf (520.5 KiB)已下载 911 次。
2位用户喜欢此帖子
Wonderful!
But I dare to note that a real steam turbine unit has up to eight steam extractions from the turbine to regenerative heaters. And not only mixing, but also surface type.
WroteI get slightly different values. ...
Hi. Using the definition for partial derivatives and a pure numerical solver.
2RegP-Ideal-Cool_Prop-95_Kr_detail.sm (162.36 KiB)已下载 1512 次。
3位用户喜欢此帖子
Martin Kraska 2023/11/12 09:10:00, Valery Ochkov 2023/11/12 14:12:00, Oscar Campo 2023/11/12 18:29:00
1页(15条)
![2023-11-08 15_08_23-SMath Solver - [2RegP-Ideal-Cool_Prop-95_Kr.sm_].png](/zh-Hans-CN/files/Download/KZD5C6/2023-11-08-15_08_23-SMath-Solver---[2RegP-Ideal-Cool_Prop-95_Kr.sm_].png)
