Multiple Binary Boolean Operators in if statement
Multiple Binary Boolean Operators in if statement - Add multiple binary Boolean "or" / "and" operators without force parenthesis - 消息
#1 已发布: 2022/5/6 22:53:10
Larry Burns
Larry Burns
0个赞,共3个帖子。
When I try to perform this if-or statement:
if a=1 ^ a=2 ^ a=3
x=4
else x =5
I end up with this due to forced parenthesis:
if ((a=1 ^ a=2) ^ a=3)
x=4
else x =5
Could we have capability for multiple binary operators without forced parenthesis enclosure?
#2 已发布: 2022/5/7 00:27:03
1,139个赞,共1,805个帖子。
Hi. The short and honest answer is not. The long and tricky answer is that you can, but you must edit the .sm file and delete the lines with (
However, unless it's for some publishing purpose or something like that, I don't think it's convenient. Also, you can neither copy nor edit it without the parentheses reappearing.
and_tryck.sm (2.75 KiB)已下载 1629 次。
#3 已发布: 2022/5/7 08:59:32
983个赞,共6,866个帖子。
Think in term of productive Bolean.
Critical.sm (30.49 KiB)已下载 1664 次。
#4 已发布: 2022/5/9 08:01:56
983个赞,共6,866个帖子。
... lot more involved. Adapted from Frank Rioux MCD 11.
Fourier Quantum 2C Mask.sm (22.51 KiB)已下载 1692 次。
#5 已发布: 2022/5/9 08:37:41
1,443个赞,共2,936个帖子。
You can always create some function to make it look like you are working with some set of numbers
3位用户喜欢此帖子
sergio 2022/5/9 10:55:00, Alvaro 2022/5/9 11:19:00, Arie 2022/5/9 16:16:00
#6 已发布: 2022/5/9 10:06:38
983个赞,共6,866个帖子。
Tanks Davide ... coded/saved.
Take care ... Jean.
Maths Conditional Davide.sm (12.36 KiB)已下载 1671 次。
sergio 2022/5/9 12:46:00
#7 已发布: 2022/5/9 11:25:27
1,139个赞,共1,805个帖子。
Hi Davide. Great idea. These functions can be very useful for translating matlab programs. They can also be extended to arrays, as the all, any and nnz functions do.
