Animation of mechanisms
Animation of mechanisms - Ber7 - 消息
#21 已发布: 2012/7/27 23:31:39
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Drilling a square hole (Cross section of the drill is Reuleaux triangle)
Reuleaux triangle is rotated around its center of gravity, and the center of gravity
moves around the center openings.
https://smath.com/wiki/GetFile.aspx?File=Reuleauxtriangle.rar
2位用户喜欢此帖子
Davide Carpi 2012/7/28 12:50:00, ioan92 2013/5/18 07:48:00
#22 已发布: 2012/8/5 03:13:02
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Drilling accurate (without rounding) square hole
The disc in the form of a modified Reuleaux triangle
moves inside a square frame . A drill (green dot in the center
of the yellow circle) makes an exact square hole.
References:
Wagon S. Mathematica in Action: Problem Solving .
Through Visualization and Computation,Springer, 2010
https://smath.com/wiki/GetFile.aspx?File=Drilling2.rar
3位用户喜欢此帖子
Davide Carpi 2012/8/5 12:09:00, ioan92 2013/5/18 07:48:00, Andrey Ivashov 2012/8/5 07:49:00
#23 已发布: 2012/8/13 15:19:53
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Square-Hole Drill (continued)
Using the coupling Oldham to convert the rotational motion
of the drive shaft to move the tool to the square trajectory.
https://smath.com/wiki/GetFile.aspx?File=SquareHole.rar
3位用户喜欢此帖子
Davide Carpi 2012/8/14 05:20:00, Andrey Ivashov 2012/8/14 18:01:00, ioan92 2013/5/18 07:48:00
#24 已发布: 2012/8/13 15:23:14
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
2位用户喜欢此帖子
Davide Carpi 2012/9/22 19:36:00, ioan92 2013/5/18 07:49:00
#25 已发布: 2012/8/16 10:41:24
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Drill, coupled with the Reuleaux triangle
2位用户喜欢此帖子
ioan92 2013/5/18 07:49:00, Davide Carpi 2012/8/22 09:17:00
#26 已发布: 2012/8/22 07:48:08
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Wankel Engine((rotary-Reuleaux triangle)
Wankel.rar (2.74 KiB)已下载 614 次。
3位用户喜欢此帖子
ioan92 2013/5/18 07:49:00, Andrey Ivashov 2012/8/22 12:40:00, Davide Carpi 2012/8/22 09:17:00
#27 已发布: 2012/9/22 12:07:33
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Chassis for Mars Curiosity Rover
Soft landing "Curiosity" on the surface of Mars was held August 6, 2012
https://smath.com/wiki/GetFile.aspx?File=Curiosity.rar
2位用户喜欢此帖子
ioan92 2013/5/18 07:49:00, Davide Carpi 2012/9/22 19:36:00
#28 已发布: 2012/10/29 06:19:16
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Rocker-bogie mechanism that can navigate the stairs.C.M.-center of mass.
1.All three wheels are actuated independently.
Climbimg1.rar (4.15 KiB)已下载 623 次。
2位用户喜欢此帖子
ioan92 2013/5/18 07:50:00, Davide Carpi 2012/10/29 07:15:00
#29 已发布: 2012/10/29 06:25:44
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
2. All three wheels are passive and the part of the rocker-bogie mechanism body is pulled
up by the external force as in the case of shopping carts.
Climbing2.rar (4.17 KiB)已下载 587 次。
2位用户喜欢此帖子
Davide Carpi 2012/10/29 07:15:00, ioan92 2013/5/18 07:50:00
#30 已发布: 2012/11/17 06:27:27
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Planar three-link manipulator
3R.rar (60.06 KiB)已下载 535 次。
2位用户喜欢此帖子
Davide Carpi 2013/2/3 18:04:00, ioan92 2013/5/18 07:50:00
#31 已发布: 2013/1/7 12:58:35
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Geneva Mechanism
Geneva.smz (40.39 KiB)已下载 1810 次。
2位用户喜欢此帖子
Davide Carpi 2013/1/7 13:21:00, ioan92 2013/5/18 07:51:00
#32 已发布: 2013/2/3 14:26:51
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Animation kinematic characteristics
Above: The trajectory of the point B, the vectors of its velocity and acceleration;
Below: the dependence of the velocity and acceleration of point B on
crank angle β (t)
kinchar1.sm (37.74 KiB)已下载 1504 次。
kinchar.smz (11.6 KiB)已下载 1776 次。
3位用户喜欢此帖子
ioan92 2013/5/18 07:51:00, Davide Carpi 2013/2/3 18:04:00, Martin Kraska 2013/2/3 17:08:00
#33 已发布: 2013/2/4 10:55:13
sublim21
sublim21
3个赞,共36个帖子。
Impressive stuff Ber.
#34 已发布: 2013/5/18 06:21:16
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Robot snake
Worm1.smz (15.36 KiB)已下载 1679 次。
3位用户喜欢此帖子
ioan92 2013/5/18 07:51:00, Davide Carpi 2013/5/18 07:31:00, Andrey Ivashov 2013/5/18 17:56:00
#35 已发布: 2013/9/28 02:45:33
lrcvs
lrcvs
3个赞,共2个帖子。
Hi,Ber7
All your post for moving parts are very, very, very...., goods, fantastics.!
Fridel Selitsky 2013/9/29 10:23:00
#36 已发布: 2014/1/17 06:23:24
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Animation spatial mechanisms
To calculate the position of the mechanism will use
techniques developed A.B.Ivanov.His work on 3d
animation mechanisms made ​​in Mapl, publishes A.B.Ivanov
online
http://forum.exponenta.ru/viewtopic.php?t=12842
Of the examples from this site I suffered in a programming environment SMath Studio
1. Sarrus linkage 1
Sur111.smz (8.13 KiB)已下载 1742 次。
Davide Carpi 2014/1/21 18:08:00
#37 已发布: 2014/1/17 06:27:14
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
2. Sarrus linkage 2
Sur3.smz (9.82 KiB)已下载 1800 次。
2位用户喜欢此帖子
Davide Carpi 2014/1/21 13:14:00, Martin Kraska 2014/1/21 18:48:00
#38 已发布: 2014/1/21 13:14:15
1,443个赞,共2,936个帖子。
Nice job ber, as usual
BTW I can't download the first animation (Sarrus linkage 1)
Best regards,
Davide
#39 已发布: 2014/1/21 15:50:29
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Thank you,Davide,now you can download the file.
#40 已发布: 2016/10/4 15:07:34
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Sarrus.sm (19.25 KiB)已下载 1630 次。Sarrus linkage
Short animation program
