Slope Stability Analysis
Slope Stability Analysis - A basic approach to find cutting points of strips with profile and slip circle - 消息
#1 已发布: 2023/9/16 05:01:44
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Ref: Example 12.2 (Page 296) - Soil Mechanics : Principles and Practice by G.E. Barnes.
The attached SM file demonstrates how to find cutting points of strips with the slope profile and slip circle.
(for an assumed strip width of 1m. which can be changed if necessary).
Slip_Circle_Barnes-Ex 12.2-TO FORUM.pdf (238.31 KiB)已下载 1124 次。
Slip_Circle_Barnes-Ex 12.2-TO FORUM.sm (320.99 KiB)已下载 1832 次。
2位用户喜欢此帖子
sergio 2023/9/16 06:05:00, dio pants 2023/10/31 02:31:00
#2 已发布: 2023/9/16 07:51:13
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
A small text correction to my post #1.
Sorry for inconvenience please.
Point A and Toe are also same.
2位用户喜欢此帖子
Alvaro 2023/9/17 17:18:00, Oscar Campo 2023/9/16 10:55:00
#3 已发布: 2023/9/16 13:06:16
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Second correction, as the variable Hvc is no longer used in the entire program. Please delete the entire line as indicated.
Extremely sorry.
#4 已发布: 2023/9/20 01:55:02
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
The complete solution to Slope Stability Analysis of above example.
Analysis is carried out in 2 parts.
1. With one assumed Center of a slip circle to explain steps involved and resulting cordinates of strips etc., and checked with ACAD drawing.
2. Program to find the minimum factor of safety using multiple arrays of centers.
Slip_Circle_Barnes-Ex 12.2-Min FS-R8-CORRECT-FINAL-R4.pdf (334.22 KiB)已下载 1107 次。
Slip_Circle_Barnes-Ex 12.2-Min FS-R8-CORRECT-FINAL-R4.sm (522.82 KiB)已下载 1760 次。
3位用户喜欢此帖子
Alvaro 2023/9/20 13:14:00, Oscar Campo 2023/9/20 06:39:00, ioan92 2023/9/20 08:01:00
#5 已发布: 2023/9/21 07:45:50
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Please make the correction as shown ( replace A with -A in page 3).
Even without this correction, the program will run in most cases, but will give
wrong values for AA for some center cordinates.
This correction is an improvement.
Sorry for the inconvenience.
Oscar Campo 2023/9/21 13:47:00
#6 已发布: 2023/10/28 21:32:18
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
An improved method to my post #5.
I get Wrong Values OR Errors when using the "Findroot()" function for some center cordinates.
This new method mainly uses "root()" function, with few supporting programs.
Slip Circle Intersection Points - TO FORUM.pdf (392.59 KiB)已下载 1066 次。
Slip Circle Intersection Points - TO FORUM.sm (247.73 KiB)已下载 1759 次。
3位用户喜欢此帖子
Oscar Campo 2023/10/28 22:03:00, Alvaro 2023/10/29 03:11:00, sergio 2023/10/30 15:59:00
