Mathcad Toolbox - Contains analogs of functions from Mathcad - Messages
#181 Posted: 10/26/2024 8:25:46 PM
#182 Posted: 10/27/2024 9:34:21 AM
Wrote... It looks strange, maybe I'll add some numbering: #1, #2, #3, ...
Hi. That's the Mathematica default notation for pure function's arguments: https://reference.wolfram.com/language/howto/WorkWithPureFunctions.html
Вячеслав Мезенцев 10/27/2024 1:26:00 PM
#183 Posted: 11/13/2024 3:47:53 AM
Plugin updated.
Changes:
- fixed image handling functions (READRGB(),...);
- the appearance of brackets has been changed;
- added the ability to explicitly specify an insert for MathcadBlock (##, #1, #2, ...).
mathcadblock-explicit-paste.sm (15.97 KiB) downloaded 1799 time(s).
sergio 11/13/2024 4:08:00 PM
#184 Posted: 11/13/2024 4:42:40 PM
Expanding the idea of numbering, we can add syntax:
## - take all as sys|mat|line
#i#j - take from i to j
##j - take from 1 to j
#i# - take from i to end
and
#i#js - sys(#i,..,#j)
#i#jm - mat(#i,..,#j)
#i#jl - line(#i,..,#j)
#i#jfun - fun(#i,..,#j)
or
### - insert as parameters: foo(x,y,###) -> foo(x,y,#1,#2,...)
##3# - insert as parameters: foo(x,y,##3#) -> foo(x,y,#1,#2,#3)
and
or
#185 Posted: 11/13/2024 11:20:14 PM
I encountered a plot problem with the list version of rkfixed(). Probably this also applies to other ODE-integrators with embedded function assignment.
In the native 2D Plot:
- When plotting a solution function along with a matrix of marker points, then the points won't display
- Yet, when using lspline() directly, both objects plot without problems.
In X-Y Plot:
- When the independent variable has the same name as the solution function (e.g. x(x), then x() is not treated as a function but as the expression x (similar with v(v) or any other name).
- A workaround is to use a variable name different from the function name. Yet this is strange, because in SMath x() and x usually are independent objects.
plotproblem.sm (30.62 KiB) downloaded 1770 time(s).
![2024-11-13 17_08_58-SMath Solver - [plotproblem.sm_].png](/en-US/files/Download/da36GC/2024-11-13-17_08_58-SMath-Solver---[plotproblem.sm_].png)
In X-Y Plot:
Вячеслав Мезенцев 11/13/2024 11:47:00 PM
#188 Posted: 11/15/2024 5:14:39 AM
Alvaro 11/16/2024 8:51:00 AM
#189 Posted: 11/15/2024 4:11:09 PM
Visualization of transformations and matrix norms using implicit plots and automatic scaling of the X-Y plots.
Matrixnormen 2D.sm (28.12 KiB) downloaded 1812 time(s).
3 users liked this post
ioan92 11/15/2024 9:21:00 PM, Вячеслав Мезенцев 11/15/2024 4:24:00 PM, Oscar Campo 11/15/2024 5:41:00 PM
#190 Posted: 12/12/2024 4:09:39 AM
I want to add a set of simple examples to the Mathcad block context menu that demonstrate how it works. Can you suggest such examples?
Similar to the X-Y Plot component. In this case, you will be able to fill in not only the input values, but also the description. You can insert arbitrary expressions inside the component.
Imagine that you can formalize the solution to a simple problem. What would you suggest as educational examples?
Martin Kraska 12/13/2024 8:06:00 PM
#191 Posted: 12/13/2024 5:18:46 PM
WroteImagine that you can formalize the solution to a simple problem. What would you suggest as educational examples?
I suggest a handbook like Martin's one, with examples where the user can reuse the code (Code reusability is the technical expression for when you don't want to say that you are going to copy and paste). Or like Mathcad quicksheets. This is my idea of a clean use of the block for solving high school problems.
BasicHandbook-nsol.pdf (352.52 KiB) downloaded 1137 time(s).
BasicHandbook-nsol.sm (327.84 KiB) downloaded 1930 time(s).
5 users liked this post
francesco rapuano 12/13/2024 6:43:00 PM, Вячеслав Мезенцев 12/13/2024 11:41:00 PM, NDTM Amarasekera 12/13/2024 7:02:00 PM, Martin Kraska 12/13/2024 8:06:00 PM, sergio 12/13/2024 9:15:00 PM
#192 Posted: 12/13/2024 8:06:09 PM
I'd like to have such things like nsol in SMath core.
How about embedded assignment, similar to FindRoot? I don't like poking the values out of S. I see that this might reduce flexibility, e.g. in the case of parametrized initial guess.
I tried to demonstrate a generic approach, i.e. you get the variables assigned without having to issue any specific command except for the generic content of the placeholder. It is just a try and fails with single variables but you get the idea.
Of course, one would like to have a solve block without the cryptic generic expression in the placeholder.
Perhaps, such a block could be created from the insert menu with pre-allocated content of the placeholder and with setting it to hidden.
![2024-12-13 13_47_32-SMath Solver - [BasicHandbook-nsol.sm_].png](/en-US/files/Download/Rkunpm/2024-12-13-13_47_32-SMath-Solver---[BasicHandbook-nsol.sm_].png)
BasicHandbook-nsol_Kr.sm (333.12 KiB) downloaded 1873 time(s).
Alvaro 12/13/2024 10:00:00 PM
#193 Posted: 12/13/2024 10:21:36 PM
Hi Martin. I put "0" as argument because there are no more args. The second could be a vector of options, like this:
or the solved variables. Also, I use "S" because this error, which I imagine that could be corrected, but don't know how hard it could be:
PD: Notice that x# : transpose(str2num(x#))*diag(U#) or x# : diag(U#)*str2num(x#) if you want to return the answer as column vector, like normal people, returns x# as scalar if length(x#) = 1.
#194 Posted: 12/14/2024 7:36:10 AM
Wrote... How about embedded assignment, similar to FindRoot? I don't like poking the values out of S. I see that this might reduce flexibility, e.g. in the case of parametrized initial guess
Hi Martin. I think the opposite: the implicit assignment of the names of the variables sought to a solution makes its call very rigid, since many times there is no direct relationship between the variables of the equation and the names of the variables that are intended to be assigned to the solution, as is precisely demonstrated in this case
Another variant among many would be to find a limiting speed and call the result v.lim, even though the variable of the equation is "v".
#195 Posted: 12/31/2024 12:07:50 AM
4 users liked this post
churichuro 12/31/2024 2:12:00 AM, Oscar Campo 1/1/2025 6:23:00 AM, Alvaro 1/1/2025 1:20:00 PM, sergio 12/31/2024 1:47:00 AM
#196 Posted: 8/20/2025 11:31:03 PM
#197 Posted: 8/21/2025 1:22:30 PM
Plugin updated.
Changes:
- find() function added.
MathcadToolbox-find-handbook.sm (303.37 KiB) downloaded 1380 time(s).
MathcadToolbox-find-handbook.pdf (183.29 KiB) downloaded 639 time(s).
There are some problems with obtaining the values themselves. Their nature is still unclear. This is the first trial implementation.
Edited 8/21/2025 1:23:20 PM
#199 Posted: 8/21/2025 5:11:48 PM
The problem is in the delayed evaluation. It is nice if you want to evaluate the solution for multiple configurations with S just storing the task instead of the solution.
It may well be fine to have this behaviour by design, but then we should not get an error message (undefined Ix).
So my proposal is
- if the solution can be found numerically with the data given at processing of the block, then store the data and not the task description.
- if the task has undefined variables other than the solution variables, then just store the task description (as it is done now but don't complain.
If you enforce intermediate evaluation, then there are no restrictions on the variable names any more. The recursivity is broken.
BTW, I'd propose to allow for scalar arguments for the single equation/single variable case.
In case you provide solvers with range specification, my ideas would be to use Davides ternary operators a
If no initial guesses or ranges are given, try to apply a linear solver.
MathcadToolbox-find-handbook_Kr.sm (331.8 KiB) downloaded 1336 time(s).
1-2-Maßeinheiten.sm (153.83 KiB) downloaded 1365 time(s).
So my proposal is
Edited 8/21/2025 5:12:37 PM
#200 Posted: 8/21/2025 6:43:51 PM
Plugin updated.
Changes:
Refactors the `find` function to be more powerful and intuitive, aligning its behavior with user expectations from similar math software.
- The set of variables to be solved is now implicitly determined from all initial guesses (`≈`) provided in the input system. This removes the need to explicitly declare all variables.
- The function signature is now more flexible. Users can either omit the variable list to get all results, or specify which variables they want returned.
- Output variables can be specified either as a flat list (`find(sys, x, y)`) or as a `sys`/`mat` block (`find(sys, sys(x,y))`).
- Introduces `_` as a wildcard argument (`find(sys, _)` or `MathcadBlock -> find(_)`). This provides an elegant way to explicitly request all solved variables, which is particularly useful for integration with `MathcadBlock`.
- The output is now filtered to return only the subset of variables requested by the user, in the specified order.
Available nonlinear solvers: FixedPoint, LevenbergMarquardt, NewtonRaphson, Broyden.
Default solver: "LevenbergMarquardt"
Understanding the Calculation Behavior. A Circular Dependency (Gemini).pdf (87.1 KiB) downloaded 797 time(s).
Edited 8/21/2025 7:02:15 PM
