DotNumerics
DotNumerics - Initial-value problem for nonstiff and stiff ordinary differential equations ODEs - 消息
#21 已发布: 2018/8/1 12:54:24
1,558个赞,共1,868个帖子。
Simple test 2.
DotNumerics.ode.test2.sm (21.23 KiB)已下载 1783 次。
DotNumerics.ode.test2.pdf (79.99 KiB)已下载 884 次。
2位用户喜欢此帖子
sergio 2018/8/1 18:06:00, Radovan Omorjan 2018/8/2 03:05:00
#22 已发布: 2018/8/1 21:57:14
983个赞,共6,866个帖子。
Simple test 2.
Works nice conventional/visual [6179].
That document, if it would come from other designer
would pass my QA [Quality Assurance].
DotNumerics.ode.test2.sm (24.51 KiB)已下载 1876 次。
#23 已发布: 2018/9/9 14:23:36
1,362个赞,共2,276个帖子。
It seems that all the dotnumeric ode solver functions fail to add the last step to the solution. In the given example, the exact solution is (approximately) met if the end value of x is increased by one step (x_end/steps).
The sheet is easily extended to whatever ode solvers by adding their name to the search list. The actually available solvers depend on what plugins are installed.
Section Math ODE precision.sm (23.66 KiB)已下载 1930 次。
2位用户喜欢此帖子
frapuano 2018/9/9 17:18:00, Вячеслав Мезенцев 2018/9/10 05:37:00
#24 已发布: 2018/9/10 06:48:25
1,558个赞,共1,868个帖子。
Updated for SS 0.99.6824. Intervals issue fixed.
3位用户喜欢此帖子
sergio 2018/9/10 07:02:00, frapuano 2018/9/10 09:23:00, NDTM Amarasekera 2018/9/10 09:48:00
#25 已发布: 2018/12/6 14:42:53
1,558个赞,共1,868个帖子。
Updated.
Changes:
- zero point issue fixed;
- added support for the simple D(t,x) definition.
#26 已发布: 2018/12/24 09:13:53
1,558个赞,共1,868个帖子。
Updated.
2018-12-24_17-06-48.png 2018-12-25_04-33-23.png 2018-12-25_04-34-24.png dn.ode.test2.png dn.ode.test1.png 2018-12-24_17-07-41.png
dn.ode.kinetic1.sm (8.26 KiB)已下载 2032 次。
dn.ode.kinetic2.sm (12.59 KiB)已下载 1895 次。
dn.ode.kinetic3.sm (12.28 KiB)已下载 1974 次。
dn.ode.test1.sm (19.58 KiB)已下载 1979 次。
dn.ode.test2.sm (18.88 KiB)已下载 1954 次。
dn.ode.Amplitude detector.sm (20.17 KiB)已下载 2001 次。
dn.ode.kinetic1.pdf (77.42 KiB)已下载 1119 次。
dn.ode.kinetic2.pdf (93.05 KiB)已下载 1047 次。
dn.ode.kinetic3.pdf (91.31 KiB)已下载 1037 次。
dn.ode.test1.pdf (115.72 KiB)已下载 1019 次。
dn.ode.test2.pdf (120.44 KiB)已下载 1002 次。
dn.ode.Amplitude detector.pdf (148.87 KiB)已下载 1058 次。
4位用户喜欢此帖子
NDTM Amarasekera 2018/12/24 09:44:00, sergio 2018/12/24 11:04:00, frapuano 2018/12/24 14:23:00, Radovan Omorjan 2018/12/24 14:52:00
#27 已发布: 2018/12/25 14:49:08
983个赞,共6,866个帖子。
Native works as well.
You can try rkfixedSteven.
#28 已发布: 2018/12/25 16:25:11
983个赞,共6,866个帖子。
frapuano 2018/12/25 19:01:00
#29 已发布: 2021/12/9 09:10:25
1,558个赞,共1,868个帖子。
SMath Studio compatibility
Plugin updated.
Changes:
- added support the mathematical form of the problem for ODE solvers;
- refactored.
sergio 2021/12/9 11:40:00
#30 已发布: 2021/12/20 16:18:13
1,558个赞,共1,868个帖子。
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin.
#31 已发布: 2022/8/21 02:43:28
1,139个赞,共1,805个帖子。
Hi Viacheslav. There are an issue with Implicit and dn_ExplicitRK45, just in the first element. Please see the attached.
dn_ExplicitRK45 issue.sm (8.42 KiB)已下载 1782 次。
#32 已发布: 2022/8/22 03:12:45
1,558个赞,共1,868个帖子。
Plugin updated.
Changes:
- fixed values of initial conditions in the output array for dn_ImplicitRK5() and dn_ExplicitRK45().
2位用户喜欢此帖子
sergio 2022/8/22 04:19:00, Alvaro 2022/8/23 20:15:00
