Numerical parameterization implicit surfaces of the form f (x, y, z) = 0
Numerical parameterization implicit surfaces of the form f (x, y, z) = 0 - 消息
#1 已发布: 2015/5/29 20:25:23
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
The grid lines are found by Draghilev Method
Method 1.
Building a line of intersection of the required surface
with the plane x = 0. This line is rotated in steps of 2 * Pi / s
about a vertical axis by an angle 2 * Pi, where s is the number of steps (the grid lines)
Davide Carpi 2015/5/31 07:19:00
#2 已发布: 2015/5/29 20:39:51
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Method 2.
The rectangular grid
ELLIPSE3d2.pdf (631.16 KiB)已下载 977 次。
#3 已发布: 2016/12/17 18:17:47
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
The graph an implicit surface depicted by lines
Examples of the idea of ​​the algorithm taken from the publication of Alexey Ivanov
http://www.mapleprimes.com/questions/219995-Finding-A-Convinient-Parametrization-Of-Surfaces#answer233804
未找到文件。未找到文件。未找到文件。未找到文件。未找到文件。
3位用户喜欢此帖子
Вячеслав Мезенцев 2016/12/19 01:43:00, Davide Carpi 2016/12/18 19:04:00, frapuano 2016/12/18 05:42:00
#4 已发布: 2017/1/29 16:56:41
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Two surfaces are taken from the site
http://xrt.wikidot.com/gallery:implicit
The calculation algorithm:
1.Find the line of intersection of the given surface with the plane Z=0
2.Through each point hold the plane x1 = C and find the line of intersection of that plane with a given surface.These lines represent a given surface.
未找到文件。未找到文件。
Davide Carpi 2017/1/30 09:18:00
#5 已发布: 2017/1/29 23:28:16
983个赞,共6,866个帖子。
Thanks for these two animations. In each one, the last three plots
stay red, though the animated plot works fine. A small detail:
each work sheet has three definitions left over at page 17.
#6 已发布: 2017/1/30 03:51:39
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Thank you Jean,
Worksheets corrected. In addition, in the algorithm for calculating along with x1 = C can be used x2 = C:
double torus x2.sm (73.26 KiB)已下载 1331 次。
2位用户喜欢此帖子
Davide Carpi 2017/1/30 09:18:00, NDTM Amarasekera 2017/1/30 11:30:00
#7 已发布: 2017/1/31 17:50:55
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
The tube in the form of a line of intersection of the cylinder and the torus (See post 7)
http://en.smath.info/forum/yaf_postst2307_Method-A-B--Draghilev-and-animation-spatial-mechanisms.aspx
Time calculation, 9 min.
Villarceau 9.sm (39.38 KiB)已下载 1313 次。
Davide Carpi 2017/2/1 05:58:00
#8 已发布: 2017/3/1 04:25:37
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Helical Tube
NonCirc.sm (53.28 KiB)已下载 1298 次。
TubeCir.sm (53.28 KiB)已下载 1353 次。
Davide Carpi 2017/3/1 06:42:00
#9 已发布: 2017/3/1 04:44:07
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
The surface of the Wikipedia
https://en.wikipedia.org/wiki/File:Tri-brezel.svg
WiciSurf.sm (106.91 KiB)已下载 1344 次。
#10 已发布: 2017/6/14 13:27:49
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Non-circular cylindrical vessels with quasi-ellipsoidal ends
Krivoshapko S.N. Ivanov V.N,Encyclopedia of Analytical Surfaces ,Springer,2015
Non-circular cylindrical vessels.pdf (1.26 MiB)已下载 947 次。
Non-circular cylindrical vessels.sm (209.71 KiB)已下载 1362 次。
Shell1.sm (255.15 KiB)已下载 1393 次。
Shell2.sm (33.38 KiB)已下载 1377 次。
Shell3.sm (34.18 KiB)已下载 1314 次。
#11 已发布: 2017/6/15 09:43:57
983个赞,共6,866个帖子。
Thanks Ber7 for the work sheets [Not finished downloading].
If you visit this document, I'm wondering:
"How to add red points in this plot".
Thanks in advance ... Jean
Maths sph2xyz.sm (13.82 KiB)已下载 1409 次。
#12 已发布: 2017/6/15 12:23:51
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Hello Jean,
Unfortunately, the 3d chart does not allow you to draw points.
Exit (hopefully temporary) -make a 3d chart on a 2d chart.
Maths sph2xyz2d.sm (21.1 KiB)已下载 1354 次。
#13 已发布: 2018/2/6 03:56:52
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Implicit surfaces in Maxima
ImplicitMaxima.sm (363.82 KiB)已下载 1374 次。
3位用户喜欢此帖子
frapuano 2018/2/6 04:34:00, Martin Kraska 2018/2/6 04:59:00, Radovan Omorjan 2018/2/6 06:22:00
#14 已发布: 2018/2/6 05:06:49
1,362个赞,共2,276个帖子。
Nice examples!
Just some remarks for those who want to play around with Maxima Draw.
  • Instead of Image region with Draw() command you can use Maxima Draw3D region with interactive zoom, rotation and resize and a settings dialog.
    Insert-> Maxima-> Draw3D
  • The performance isn't overwhelming, as the image is recalculated for each interaction.
  • The snippet "draw" provides help texts for the available draw commands and options.
  • Follow the link in my signature to see how to configure SMath with Maxima.
ImplicitMaxima_Kr.sm (492.51 KiB)已下载 1415 次。
4位用户喜欢此帖子
Вячеслав Мезенцев 2018/2/6 06:15:00, Radovan Omorjan 2018/2/6 06:22:00, frapuano 2018/2/6 10:28:00, Fridel Selitsky 2018/2/6 05:08:00
#15 已发布: 2018/2/21 16:41:18
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Continuation:
MaximPlus1.sm (237.91 KiB)已下载 1344 次。
frapuano 2018/2/21 18:56:00
