Newton method
Newton method - 消息
#1 已发布: 2023/4/8 16:07:23
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
I cannot use the roots function and must use one old good simple method by Newton.
What can you say about it?
Newton-Eng.docx (1.07 MiB)已下载 1010 次。
Martin Kraska 2023/4/9 08:50:00
#2 已发布: 2023/4/9 08:56:19
1,362个赞,共2,276个帖子。
Very nice.
I had problems when reproducing your 2D version. Depending on initial guess I got errors "requested matrix element does not exist". The situation seemed to improve a little by pre-allocating the vectors X and Y yet it didn't become really robust.
So instead of assigning to j+1 elements I used augment() to add new points to the iteration history.
This is the original version:
Newton2D.sm (21.4 KiB)已下载 1581 次。
And this is the modified version.
Newton2Da.sm (19.03 KiB)已下载 1703 次。
#3 已发布: 2023/4/9 14:27:18
983个赞,共6,866个帖子。
... can't find 2nd root
2nd root confirmed exact.
Solve(f,q,x0,x1,TOL) Copy.sm (162.62 KiB)已下载 1697 次。
#4 已发布: 2023/4/9 14:33:35
600个赞,共1,381个帖子。
Tried to solve your functions with al_nleqsolve().
Newton.sm (13.85 KiB)已下载 1618 次。
#5 已发布: 2023/4/9 18:19:38
1,139个赞,共1,805个帖子。
Another way, keeping the mathematical formulation and the iteration algorithm separate. As here.
Newton2Da.sm (13.34 KiB)已下载 1757 次。
#6 已发布: 2023/4/10 12:25:58
983个赞,共6,866个帖子。
Thanks Alvaro, added to my next Samples visit.
Take care ... Jean
#7 已发布: 2023/4/10 16:21:38
600个赞,共1,381个帖子。
Actually, you can.
#8 已发布: 2023/4/10 20:29:31
983个赞,共6,866个帖子。
An old vintage in Smath ... two examples.
Take care Valery ... Jean.
Solve_roost f1(x,y). f2(x,y).sm (27.42 KiB)已下载 1690 次。
#9 已发布: 2023/4/11 14:21:16
1,139个赞,共1,805个帖子。
Two variations added.
Newton2Da. v2.sm (38.35 KiB)已下载 1695 次。
Newton2Da. v2.pdf (152.11 KiB)已下载 1165 次。
sergio 2023/5/3 14:29:00
#10 已发布: 2023/5/3 00:37:31
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
From my future article
Если уравнений не два, а три, то матрица Якоби будет состоять из трёх строк и трёх столбцов. При этом графически отображать решение придётся не двумя кривыми, а тремя поверхностями на 3D-графике, причём их взаимное пересечение и будет отмечать решение (задание читателю).
Слабо!
Alvaro 2023/5/3 03:21:00
#11 已发布: 2023/5/3 12:02:25
983个赞,共6,866个帖子。
You may find this Treasury useful/productive.
Solve(f,q,x0,x1,TOL) Copy.sm (300.16 KiB)已下载 1718 次。
